  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
OMG!!!
Forum Top 20:
GTS-t VSPEC (0)
Ultimate Postwhore 45,060
chaos (0)
SAUQLD Member No. 17 16,156
predator (5)
project32.net 13,488
inark (0)
SAU VIC Member #31 10,258
BelGarion (0)
Registered User 9,806
RedLineGTR (10)
It’s Black & Very Shiny.. 9,612
SHUTO-BOY (0)
Super Sleeper 9,303
skyzerr33 (0)
Lost a planet u have hmmm 8,276
darK (0)
fully sick u leh. 7,970
Pva_Glue (0)
益力多 MOD 7,827
funkymonkey (2)
私の自動車は私の陰茎の拡張です。 7,655
SW20-GT (0)
Team Raceworx 7,037
G0DF4Th3R (0)
[ERA]racing 6,751
Ska (0)
Suxorz to be m3! 6,736
SmoothLine (1)
Don "Smooth" King 6,702
Duncan (2)
SAU NSW Vice Pres 6,627
13_devil (1)
Registered User 5,808
gtrken (0)
Old Member 5,499
Adrian_perth (0)
Part-Time Nigga 5,459
strutto (1)
4D 5,394
I have overtake SMOOTH! :)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
