  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I'll give you a flower: :flower:
hey josh.. you may actually know the answer to this one:
http://www.skylinesaustralia.com/forums/sh...newpost&t=64582
Can't help sorry. Never had to pull them apart. I've only had then in an out of the car to play with heights.
hey strutto.net.. does strutto.net maybe has fast.net on there.. you said "speak to me in a few days"..
this was "few days" ago :rofl:
Hmm wasnt uploading to my site sorry :rofl:
It's all done now, but the hoster hasn't published it yet...
Which file was it again?
She's still working off the 12 roses I gave her last valentines day
I don't recall you ever giving me roses on valentines day.... The only flowers you've given me on valentines day was in 2001 when I worked at the police and I got tulips.
I remember all these things.
The page you have requested has been categorised as containing inappropriate content and as such, access to the page been denied.
                 If you believe this        is in error, please contact the Service Desk on 1800 198 175
The Queensland        Health Policy Statement regarding Usage of Internet and        E-mail Services can be found HERE
Death to Content Filters...
Ahhh the good ol Southern Zone Service Desk number
Strutto... I take it you work at Logan or GC hospitals???
and how do you get internet access??
I need B1.rar
I've sent the guy a message... Gatty on here if your interested... He's on most nights, but I'll start upping it to my host now...
GC Hospital... You? How do I get internet access? Well I put the bloody WAN in for QH, so I'd want some sort of access!!!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
