  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
My mate has an old 86 magna.. his 2nd car is a R33 GTR :D but the magna always gets good use.. surprised its holding up. He's actually owned in since I've known him (about 7 years!)
Yep, thats why I have put the mini back on the road I was going to sell it but like most cars its worth more to me than to someone else, and there is no way I will be using the R the way I have used my current skyline. Have done over 50000k in the 2.5yrs of ownership. Have loved every minute of it and has yet to have any real problems (just one seal let go once, kinda self inflicted) but I am anticipating the GTR being a "little" more expensive to run and I don't want to have to leave it in shopping centres and stuff. Beside its more fun using the mini in traffic and parking situations and leave the line for the open road driving where you can use the comfort/power/handling characteristics of the skyline.
