  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Select * From Ska
Delete Ska;:rofl:
Bah should be this (If using MS-SQL I dont deal with Orical so it is probably different):
USE IslandHoppers
DELETE
FROM MoronicDrivingStyle
WHERE Value = 'YES'
AND Name = 'Ska'
AND Name = 'MJ'
AND Name = 'knore'
GO
But that is transact SQL I mostly deal with actual database architectural coding which is quite different then T-SQL :rofl:
space saver spares require rather high pressure levels too, i rolled a tyre off one of my rims, fark it smacked the suspension about too, theres black rubber marks from where it whacked everything underneath including the wheel arch
skyline jack can eat me too
60psi in my space saver :) Ergh... I hate motorbike tyres... My poor Skyline is crippled...
Oooh the detectives were just at my house according to the Missus...
Showed her a wanted poster with the lady next door on it ?!? Asked her a few questions about when she's home... What car she drives... etc, etc...
I might be on the news in a few days... :)
