  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Also when your breaking from doing 170 (this was on a legal drag strip) and your breaks start to shudder .. what does that mean?
FARK... Thats a low 13 sec 1/4 mile time there... Had no idea your car was that fast...
Shuddering brakes: Excessive runout on your rotors...
Solution: Machine the rotors or buy some upgraded DBA rotors...
Be warned if you only machine the rotors the shuddering will return...
Yeah WTF were you doing? I was trying to catchup to MJ I said it once and I'll say it again 90% of AUSTRALIANS CAN NOT MERGE! Bah had to swerve in front of that Z4 to frigging miss collecting a 4x4 stupid thing!
yeah ****ing hell man im so ****ing pist off
i was going to catch up to you .. and then all of a sudden that ****ing car would not merge in the merging lane so im ****ing down gearing and the wheels kept spinning when i down geard
then in the ****in 100 zone all the cars come to a halt so im trying to ****ing get aorudn them then they start moving but so slow .. so i go to take off and i have to down gear again and for some reason as i down geard it just locked up almost threw me side ways ..
im like **** this i wanna just get on the high way so i throw myself onto the painted island shit and over take the cars on the inside and this ****in car as im trying to get on the on ramp decideds he wants to get on too .. and then i cut him off and hes all up my arse and the car infron is doin like 20 on the ****ing on ramp
i was so going to ****ing loozse it .. ****!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
so i get home after grinding half my ****ing gears, and the diff jumping .. to find my ****in azenis are ****ed up due to having to lock up and all the down gearing, i swear to ****ing god im ready to ****ing murder someone
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
