  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
sir warwick... i'm off to school now for some research work..... will be back to play with you again soon...
in the meantime... go easy on moderating my posts k :(
but when you're away is the best time :D....coz you can't defend your sexuality:D
Predator was swallowed by a mosquito...
Nexus is a cop...
Chaos and Ska have eloped to run a deep sea fishing charter...
Palidan's mum has 3 saggy tits...
That's right
and for future reference I WILL be confiscating any R33/34 GTR's that I see
heheh
