  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
series 2 R33 equivs....Neo-25GT had some of his go after just 15,000Ks...they must really be fragile. Now with the boost running...they just don't have the go to fire under load properly...Idle has always been rough on and offish
Ahh I see... They are a fragile bit of gear... I treat them like Uranium when I'm changing plugs...
I've been lucky so far though... Touch Wood...
