  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Lucky man marrying a girl who is into the car scene, Ben you should have been there strutto when you went to get flyn33 and we were sitting round talking, 2 girls just sat in their boy freinds cars, didnt come out didnt say hello,just sat there , and when ask why they werent comingout they're bf just said, oh she doesnt like cruising, so why bring them?!?!?!
Was that EVO's gf and James' passenger??
EVO got chewed out for bringing her!! :):D
