  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
she knows my true feelings, it was something i did that was bound to happin with her unless she became a nun
Oh, oh my, yes indeed...
So her parents are strict? seems a little nieve of them to expect her to not put out some love at her age... assuming shes your age. Its a part of life... For them I reccomend building a bridge lol
