  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Now think Mountain...  Think really tight downhill bends with cliffs on one side and drop offs on the other...  Think crosses on the side of the road where people haven't been so lucky...  Think dark, moss and leaf covered bends...
man.. now i'm feeling the goosebumps too~~
yup, thats me, how r ya?
oh hang on.... jacobs creek.... i saw you b4 too :D you were there with your friend arent you? ... unless i got the wrong person...
i was in a sexy black 32 with equally sexy white rims ;)
*head inflating
there's nuttin to stop a GTR from going downhill...too many ppl think too highly of the 4wd system in the GTR...n they end up killing the car and/or themselves.
i have told a lot of ppl...the GTR can and will bite you if you dun understand it...ask glenn if pushing the GTR hard is idiot-proof...he'll let u know better from a passenger's perspective.
