  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
lol nah i wasnt that good,
tho in the olden days i think i was chasing predator or someone up the total posts on the forum list
mmm word of warning for everyone about tommrow night, dont drive outside your own abilities, if the car in front goes faster dont try and keep up, that road is very dangerous
i know if im goin i wont be goin crazy
back in those days we had postwhores like boxhead and chaos... damn those boys could post useless stuff rapidly in a true post whore fasion
then again we do wanna keep this thread with a certain level of relevance and not just fill it with useless mindless spamming and pages full of nothing
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
