  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Ska, Job is still ****en boring. I organised to go for an interview friday lunch and continue it after work but I think my grandfather is ill and I would like to withdraw my application.
My grandfather is sick and god bless he gets better. He's got pneumonia. My sisters mother in law died of pneumonia 7 weeks ago :( .. but this job I've decided I dont want. One of my main gripes is the peak hour traffic.. and the job is like 2 minutes from my current job. So yeah.
