  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Tag him anyway...
And then tell him Fords suck...
And then tell him unless they have a turbo...
This guy has the worst case of turbo envy ever.....very painfull....:awww yeah....when I turbo it......when I supercharge it......"
Ahhhh derrrr....they come from the factory like that moron.....why would you do it aftermarket to an NA????
