  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
no when used as a spray.. although now that you mention it.. (makes mental note for next time).
i guess though if you were dying from an infinitely deadly spider bite, a good smoke could take some pain out of those last moments though :D
and a healthy dose of morphine
lol...what scares me is the self medicating button...where you go..."hmmm I THINK I can feel pain....better give it another hit.....ahhhhhhhh.....hang on....is that more pain???....I think it IS!!!!..:D"
haha.. when i was in hospital i had a button, which was even better as you got a cute nurse to administer it for you.. or at least she *looked* cute after that hazy effect after a few shots of morphine :D :D
lmao@looked cute after hazy effect....morphine goggles
maybe wait until the SAU night out so he is so blind he won't notice you working him over with the bat.....then he just wakes up in hospital the next morning and hey presto......morphine :D
Never mind the 6 week stay and permanent disability which he will have as a reminder :D
Permanent disability = more money for mods!!!
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
