  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hehehe sunday started drinkin at 10am then drank all day at the oz hip hop fest then went to the after party with Hilltop Hoods and got even more off my face then had to go to work in the morning which was funnily enough the same time I got home. so yeah just a lil hard. im taking it slow tonight read to crash
