  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
here's a thought....if you all went out and actually GOT OUT OF THE CAR (and I don't mean at a cruise stop) once in a while....the chances of meeting a woman would increase immensely :D
Cmon we do, I think it is a combination of my face and body that scares them off :D
Plus when they ask, "So what are you doing next weekend?" and you reply "Well next weekend I have my kids, how bout a picnic in the park?" ZOOOOOOOOOM They are off faster than 1 male hampster stuck in a cage alone with 100 female hampsters!!
glenn...you have been doing some serious whoring....HTF did you rack up that sort of a lead on me in 1 day???
frankly speaking... i dun noe :D ....
wasn't intending to whore so much last nite but it was fun when fyn33, James, Nick and Matt came on... and we just whore till the wee hours of the morning :D
Maybe you should be targetting the single mothers :D .....they may empathise
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
