  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Still a long way to go Sam, betcha you in the top ten this week :)
User NamePostschaos 1830Ska 1276GenesisR32 1144strutto 1133Nexus9 994predator 976yamutha33 939SmoothLine 839NA_R33 775mindflux 524EVO83 515BelGarion 502jaqule 435FYN33 374
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
