  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I revived an old thread about it , funky was having a group but on a different kind , some back lighting kind , just seeing who know where I can get them , if I can't I will just go for the el kind
Oh his bling bling eh :P Kudos for the pics, thought I'd use them in my sig, GOD DAMN THEY ARE FUNNY!!!
I do own the copywrite on those photo's Ska.... hmmm lets see at $1.00 a pic x 2 multiplied by 1,985 posts = $3970 you owe me.
how would you like to pay sir?
oh yeah I go past there on my to and from work everyday and if I go home for lunch as well.
So there would be a good chance. There is another Gun Metal R33 that goes past there as well, looks like mine except for crappier wheels and lower spoiler on the back and the bog standard number plates
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
