  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I reckon we all go up to stntgirl's place for pizza!!
ACK brb kids are hungry, going to get scottish food, aka McDonalds :( see yas in a couple hours :D
yah.. i reckon yas all should come here for pizza... having a slow morning... but it is easter sunday....
and after my night out im not too upset that its quiet....
You tell us Ska....do you have something planned?
that must mean the kiddies are heading off??
James - hope you feel better soon dude.
Yeah just got the call and was told to have them ready at 2pm, so after that I can go into hoon mode :(
Hey I drove out past boonah (kalbar) yesterday, nice drive, pity bout the frigging charade drivers going 80 in the 100 zone!!
OH OH OH Also there is a quarter mile marked out where beenleigh-bauedesert roads meet beaudesert nerang roads, strutto wanna get in a bit of practise?
anyway back after 2pm guys see yas!
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
