  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
My car did 256.6rwHp bout a month ago.. does that mean i can take a NSX???
the japanese have a nasty habit of under-quoting the real horsepowers of their cars so as to pass emission and stuffs.
hint - heard that the new NSXs are gunna be turbocharged but no available yet to the public.
so to answer your question, its a flat 'no'. you cant bet an NSX... yet....
i'm already going to that half day skidpan on the 24th.
Yes it needs a tune badly. Where can I go?
Gavin Woods.
read his reviews. The GC guys practically worship him.
http://www.skylinesaustralia.com/forums/sh...ght=gavin+woods
had teh ass all over the place on the way home,
o teh joys
ross was shitting bricks
Neil, theres something i have been meaning to tell you.
WARM HER UP FIRST!!!... Aaron and James were pretty surprised @ how you were driving her when you left the place last nite.
Its a Turbo Inside mate :(
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
