  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
last time, Nick.
engine oil - go motul
diff and gearbox oil - go redline
brake fluid - Castrol GP600
Coolant - anything concentrated. I went Repco
spark plugs - NGK copper/plat/irid.
Oil Filter - Ryco
Petrol Filter - PLEASE GET NISSAN ORIGINAL
mmm yeh well it depends on how much time u have glenn.... if u dont have time then i guess they'd be no point in doing much
get everything done once and for all. dun stop halfway.
watch Neil and learn from him. i will be there to guide.
krazy with a K
anyday this week, i am free most of the time,
and maybe heading to noosa tomorrow for monday and tuesday maybe wednesday
protect your car.
Noosa = seawater = salt in the air = air into your car = RUST.
nick, get the stuffs first.
both of you still need to get the DIY Brake Flushing kit. Its $7 from Supercheap. It a long transparent tube with a black rubber head stopper at one end.
also, you need to get 2 suction pumps (like the ones you see in my gearbox oil change thread)
AND PLEASE BUY AT LEAST 2 CANS DEGREASER ... EACH!!
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
