  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hmm... that's why i'm wrong.
was under the impression that 1.2.bar = ~ 12-13psi. that's my math outa the window i guess.
When the Turbo gets upgraded on my car in about 6 months time you can have mine Glenn, then you can run it how ever you like :D
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
