  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Yeah I'll post the results...
Interestingly enough, one of the only known 33 Skyline GTS25t's to crack a 12 on the stock turbo was a SEDAN from QLD at Willowbank...
Steve aka 4Doorz on the forum...
Goes to show that 4 doors are faster :(
Did I say this further back in the thread?? :D
So that is the only skyline that we know of to crack 12's on a standard turbo... is that right?
its not a whole bootlid in fibreglass from what i know, just a mould that sits on top to make it sit flush.
You can also buy a complete carbon fibre one but thats around the 900 to 1k mark
I have looked at these options and cant justify that much so when i get sick of mine the stealth wing will do
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
