  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
WTF is a "NEO" motor???
Vehicle 1998 NISSAN SKYLINE R34 25GT
Price $28,000
Kilometres 32,200
Body 2 door Coupe
Colour Black
Transmission 5 speed Manual
Engine 6 cylinder Petrol Multi-point injected 2.5 NEO 6L (2497cc)
Reg Plate 741GSO
Reg Expiry FEB-2004
RWC Not Applicable
Brief Comments Cheaper insurance than turbo, real street pressance + 20 Months warranty!
Long Comments Non-Turbo RB25DE NEO 2.5ltr Inline 6 (152KW) 5 speed manual, 18" Altstadt hyper-black rims, Medium stiffness/Low king springs, Kakimoto Racing 2&3/4" cat-back exhaust (w/ removable baffle-plate), mine's/k&n pod filter (with custom chromed piping), nismo clear side indicators, silver pedals & silver gear knob, blue neons under dash, dark tinted windows, front bar just re-sprayed, always serviced by Garry Wood Auto-Tech and is loved dearly! Drives like a dream and has awesome street presence (unless a fararri is next to it) also includes 20 Months warranty. VERY regretful sale... Pictures truley dont do it justice!! for more pictures or info, please e-mail me :)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
