  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
or even this one if you like 33 gtrs?
http://www.prestigemotorsport.com.au/au/st...sp?StockID=1558
i love this line
Power output: Claimed to be 600ps, previous (lady) owner took the car up to 270 km/h.
lady with balls
OMFG LOOK AT THE FRONT BAR!!!!! :)
