  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
ahh simex.. i got my best time so far on simex :cheers: then i got these ZE326 and if anything they are same, if not worse.
those damn v8's.. see its all rigged.. with the v8's they're so damn loud you could hear them with 5 helmets on.. its good though when they are ahead i reckon, gives you something to chase and try that little bit harder
ill let u give it a run strutto, it will actually be really interesting to see if you could get a better time.
the engine wont blow its been fine since we did it weeks ago :cheers:
I reckon the mph will remain fairly constant... It'll be the 60ft times to watch...
if i get some time after the tyres get put on ill find somewhere to try launching a bit..........with these tyres will they be slippery when they are new like the last ones i had and will apparently grip better once i drive a few hundred kms?
They'll have plenty of time to get seasoned on the way there... Maybe do a burnout for the first run??
