  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
ahh simex.. i got my best time so far on simex :cheers: then i got these ZE326 and if anything they are same, if not worse.
those damn v8's.. see its all rigged.. with the v8's they're so damn loud you could hear them with 5 helmets on.. its good though when they are ahead i reckon, gives you something to chase and try that little bit harder
ill let u give it a run strutto, it will actually be really interesting to see if you could get a better time.
the engine wont blow its been fine since we did it weeks ago :cheers:
I reckon the mph will remain fairly constant... It'll be the 60ft times to watch...
if i get some time after the tyres get put on ill find somewhere to try launching a bit..........with these tyres will they be slippery when they are new like the last ones i had and will apparently grip better once i drive a few hundred kms?
They'll have plenty of time to get seasoned on the way there... Maybe do a burnout for the first run??
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
