  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I agree about jasons GTR glenn... AAA condition
yup.
best yet, he told me that there are still heaps of GTRs in even BETTER condition auctioning in Japan!!
*damn i should have applied for a Japan Uni or something....
Glenn, I just thought that you should know that apparantly I have a thing for you. Not quite sure what it is, but yeah. Just thought I should tell you instead of hearing it from Matty. :D :D like that biatch?!?
LMAO that is the biggest cop out ever.... Well covered up sammi girl!!
:soft:
PS: glenn she dreams about u running through feilds of roses... Its really all quite sweet...
PPS for anyone who is taking ths seriously we are kidding, i think :D
so you wanna be the alpha male in this relationship?
yeh i seen some really nice 33's come through prestige all within what im lookin to spend
ok... and you also have to consider insurance costs as well, putting aside money for mods/servicing/repairs, etc.
i have some friends who dun wanna come out cruising becos they ran outa money for petrol.
all of things to consider.. its like a big commitement... only thing is that you can't ask it to sit or fetch :D
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
