  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
:@ i hate uni students why if something doesnt work or go as bright or quick as they want they crank the f**king voltage more :@ errr now i have to wire wrap 3 20pin IC's into this circuit board, either that or replace the whole board and solder in new everything :@ damn u people :@ i want a bludgy day not a stressful one
afternoon peeps :)
ahhh what a glorious way to spend a day off....
changed the engine, gearbox and diff oil....thought the line deserved it after the flogging I have given it over the last few days
tis quiet in here today :)
