Warwick?! It was you who got owned??
What'd you do/
was being silly and shot past this chick in a celica who was antagonising Glenn....didn't realise there was a cop following us in an unmarked car
He was pretty good about it....said he was going to pull over the celica for being a dick, then I pulled my brainiac move so he decided to do me.
He actually asked me how many points I wanted to lose, so I think he adjusted a few details for my benefit
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
was funny...he goes ..."where have you been?....at the carpark?: and I said "nah just for a drive to Fingal"....then as he was looking down writing the ticket (I was sitting in the cop car with him), this stream of skylines fly past, and I was praying he didn't look up :)
mighta been a bit obvious
Bub is due in September, so if I go for 3 months without it's all good, which is prolly the best option, coz I can't see myself surviving on 1 point for 12 months....I just don't have that kind of self control :rollseyes:
The cop asked me how many points I had left and I foolishly said 6, so as not to sound like a regular offender....if I had said 2 he might have only done me for one point....DOH!!!!....he was actually a preety decent guy...asked all sorts of questions about the line etc and wasn't condecending at all
Good thinking.. I was more thinking of the bub and the rush to the hospital with no licence...
:sorry love, you'll have to drive yourself, I've got no licence"
yeah....just catch a cab....I'll call one for you now....no rush is there? :P
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
