  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hey matt :wavey:
it appears! you missed out on last night. Was a great one.. so many skylines..
Yeah I know mate... real bummer...
My front bar wasnt ready in time and the engine decided to kiss me goodbye it seems... got oil seaping out a few joins... Must take it to gavin this week, last week was just too busy...
SO i decided to go and get buck wild watching the footy :P
could be fugged welsh plugs or something? sounds expensive though..
you can have the bottom end of my r31 :) thats in fine condition.. good compression across all cylinders. Pity the rest of car is crap..lol
Lmao....
I dont think the egine is FULLY broken... maybe just the combination of a few things... The drippping sound got worse yesterday arvo... my brother was like wtf is that???
Ok.... its broken :P
lol
hey guys whats happening?
I just got myself a stealth wing today and i dont know how to mount it on the car :P
theres no screws for it so it looks like it needs to be siliconed on or something and i dont know what to use that wont strip the paint, any ideas?? it will give me something to do on this lazy sunday afternoon
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
