  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
what needs doing to yours? looked ok to me??
mine should look like it did before i moved up here.. and that was pretty shmick.. may actually be better as i have the better sideskirts fitted.. Will be interested to see how good it comes back
