  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I mgiht have to sit thursday night out as well. Sinbad may be at the docs. Depends on whether we get his new lungs or not.
We may go if we are allowed in brutis :)
Bah I need new lungs... or some of that gas they give you when you can't breathe properly... :)
No comment re brutis :(
