  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
i will correct u erin i have been workin at maccas for just over 7 months now, i talked with the bank a few months ago and they said it was fine where i worked just wasnt there long enough. so they said come back after i been workin for 6 months. Im gettin on average 25-30 hours a week which works out to be almost $300
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
