  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
blah got paid but looks like another tight 2 weeks :rant: i cant afford shit no more :mad: i might as well stop tunin this chick i cant afford to take someone out lol
Welcome to my world, now you know why I dun want a gf atm, they just cost too much, got more important things to spend money on, like zaust, EBC, FMIC, etc etc etc, WAY more important than stoopid gf, they're only good for one thing :rant: :rant: jk no offence intended to all our lovely women Members who might be reading this :cheers:
isn't it funny how you call one place to get a quote on something....make a booking, then call another place....get a better quote (2/3 the first one)....call the first place back to cancel the booking, and suddenly they can "match" the other persons quote......
WHY DIDN'T YOU GIVE ME YOUR BEST PRICE IN THE FIRST PLACE DICKHEAD!!!!:rant:
not very good business practice really..."we'll see how much we can sting this guy for first"
the automotive industry and its sattelite industries really piss me off
just click on the menu up the top > select thieve > enter the username of the person you want to thieve from and the number of points you wanna try for > continue
be warned though....if you fail, you lose the number of points you were trying to thieve to the person you were trying to thieve them from as well as 50 credibility points
bugger....it also seems that once you have purchased something eg. a coloured username (which I think was about 800 points), if you wanna change that and purchase a different colour, it is a shitload more expensive the second time around......so choose wisely
lol@smooth & squizz
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
