  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yeah james....boost comes on quicker and engine seems to rev a lot freeer
getting some popping in the upper rev range now, i think it's over-fueling (I hope, coz i don't really know what pinging sounds like), so the SAFC prolly needs a re-tune
I am hoping to get a cooler in the next few weeks (sshhh...don't tell the missus), so might hold of on the re-tune till then to save having to do it twice
Wouldn't mind getting someone with an experienced ear to come for a ride in the meantime, just to reassure me that there is no detonation though
mmm i was under the impression that when ur engine started pinging the check engine light came on, or mabey that only happens with a pfc,
I have NFI
the same thing (popping noises in the upper rev range) happened when I changed from a pod filter to a Blitz panel in the factory box....went back to the pod and it was gone....pretty sure it's the SAFC tune
i might go for a run up mt tamborine or mt nebo-glorious just feel the needs for the corners and its a lovely day. I dont have a mother so I just got another day off work :)
/me dances.
hmm car all clean and the oils are right, just need tog et this 100k service done next month, rego this month :)
perhaps get adrian or mj to have a fiddle with your safc settings, perhaps make sure its safe for the time being?
yeah...might call on hero boy to have a look next time he is about....don't have any dyno info with AFR's though so it would be stabbing in the dark a bit...
    • Welcome to !
    • As I've said elsewhere, I am using the stock intercooler piping path in the engine bay, and a return flow cooler, and making ~250 rwkW (without any effort put into trying to turn it up past there just yet) and expect to be able to make some more, and frankly, I would be perfectly happy with 260-270rwKW. This is peak road Skyline usability territory. You go past there and, sure, the car will snap necks more when it's on boost, but it will also break shit all the time, cost a (even larger) fortune in tyres, etc etc. Anyway, I also do not like the over-the-fan pipe path, and you don't have to do it.
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
    • Not easy to quantify wrt something like how many fractions of a second slower it would be over 0-100. But given that a 250-300rwkW car is able to do that launch sprint in 5-6 sec (and faster with appropriate tyres, and surface)..... giving up as much as a second would feel like torture. A ~450HP capable turbo is not going to make lots of boost in the 2000-3000 rpm range. So, whilst with some boost on hand it will be faster accelerating in that rev range than your engine currently is NA, it will not feel like a fast car until the boost is solidly in. You know what your car feels like right now when you open it up at 2000rpm. if you've ever been in an actual fast car, you will appreciate that the NARB25 is.... not exciting. Well, add some boost and it will be better. But shorten the intake runners and it might not be better at all. It might come out better, but it could end up feeling the same. For me, it's not the 0-X km/h sprints that matter. It is easy to fry the tyres with anything over 200 rwkW. You can't use all the power available in 1st and 2nd anyway, you have to modulate the throttle. What matters is how the car reacts when you're driving in traffic in 4th or 5th and have maybe 2000 rpm on board, and you want/need to add some speed quickly, and don't have time for the downshift. It won't make boost, it will be all NA (at the speeds we're talking about - remember how fast you're going at 2000 in 4th! and don't plan on breaking the limit by too much.) So giving away NA torque is not what I would consider practical for a street car. And retaining that NA torque builds boost faster which makes the car faster. The flashy plenum is not actually better, unless you're looking at a track car where you can keep it on the boil all the time.
    • So how much difference does it make you think? Like 1 second in the 0-100?  I was have smaller turbo so hopefully that spools quick GTX2871.  currently it’s NA so you can imagine pretty slow, but I do want fast accusation a little as there’s not many places I’ll be driving where I go over 80 even near me. So 0-60 and 0-80 targets
