  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
james: oh ok, coolies you got it in. Yeah, its a bit hard to judge. But a torch does wonders.
That jar thing is a ****er.. but i worked how to do it much easier later.
Luckily the fuel guage sender is a bit further away. They are still inaccurate as crap anyhow
the reason i ask... i am after a fancy knob for my auto , and wondering one may obtain a fancy knob for an auto
Negative... I have seen them... I may be able to dig up a pic... But yeah... It depends on how the shift lock works and whether it has an OD / Hold button...
dang.. i know how i can do it. I can remove the big shifter, splice the wires for the "power" button (yes its a "power" button on an r31..wee), and squirrel it away to a switch somewhere else. And just have it so its always engaged and you just bang it up and down.
The main problem is finding a manual knob with a circumference that will fit over the auto stick.
hmmm.. i am on a quest for knob! :P
i'm starting to do it up a bit on a cheap-ass-budget.. thought why not.. Not much more i want to do to the R33 styling wise.
hey james.. does it make that cool sucking noise when you turn on the ignition and its priming up. I love that.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
