go front strut bar and sway bars.... front and back.... even with stand springs and shocks, you will still easily out manevour most cars....
you trying to get me broke?! :)
you keep giving me ideas to add more mods to the car, probably end up doing a RB25DET engine transplant and a T88 and nos.... :headspin:
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yeh but dont forget exhaust...will be lower than your standard one
not really benny boy... max piping size for NA should only be 2.25 inch catback and muffler size is almost same as stock....
you go anything more than 2.25, you will lose back pressure.... less torqy....
ME giving you ideas?? :confused:
i would go handling first..... no point spending thousands to squeeze a few more KWs outa the car...
awesome handling makes you a better driver...
I've got a twin cannister 3.5" exhaust sitting in the garage :)
ya, I'm going for tyres first Glenn costing me a butt load too.... almost half my uni tuition.
can sometimes even be just be the gaskets or rubber mountings.. gaskets are like $2.50 to replace
where can i get this checked out? at a normal garage???
yup.. not cheap..
krawler: no.. they're just spring and shock setup.. i sold my old set for $200, they were sitting around for ages
Doesnt coil over simply mean the coil is over the shock?
Meaning that most cars are coil over factory.. The term coil over is normally targetting adjustable gear though.
i know... It was on the NA, but got it taken off for compliancing.. and power loss.
now i'm stuck with a stupid rattle.
get 2 jacks and a creepboard.... rip out the heat shield....
if not the heat shield... hammer the resonator gently to check for rattling...
i think the difference is.. with coilovers, the shock is actually welded to the bottom of the spring, and they are basically one unit and cannot be separated. Most things can be adjustable.
With a spring and shock setup the springs and shocks can be separated and changed independently. In that setup you can adjust the shock, but not the actually spring height or anything like that.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
