  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
New job's going great sorry. I got involved in talking to someone :D
It's busy. HEAPS different to my old two jobs. You have set timelines that HAVE To be completed by the deadlines. It's great.
Only thing that sucks is I actually have to work for my money now. And I've got internet access where I didn't before. So before when I had no work, I had no net. Now when I have net, I have heaps of work.
Plus at the moment its end of month reports that are due in sydney and then in paris by 10th June :)
I had three public holidays and one full week in my last 4 weeks of work after I resigned. I took a sickie because i had the time, but they argued it and took the money off me because i wasn't entitled to it. Pitty they already paid me for it and then took it away.
I'm just glad to be out of there and not putting up with the bullshit anymore.
My new company rocks and they pay me alot higher than the last place. I have to work alot harder though. Even though that involves sitting at a PC, so its not really hard yacka.
Cant wait to get my GTR back. Been in Brisbane for three weeks and no skyline cruises yet.
Motor was getting pulled out today.
CalaisT3RBO: i saw that.. been on there recently scouting for parts for my RB30E turbo conversion actually..
some guy came around earlier and picked up the 5speed i had.. only advertised it on there on saturday and got a heap of enquiries.
Yes, it is my car in there at the moment.
It's not very healthy :) Well not when we heard it about 3 - 4 weeks ago.
Nice car but! Looks hell clean. Just sounds like a rotary :)
nice 2 see u out and about on sat night so many pplz =|
Yeah we hadn't been down there in a while, and I know why, heaps of people, it's just boring.
Plus props to the cops doing rbt's on the way out. More rbt's and less defecting :)
Yeh was there standing around with 61rly and some other mates..... saw some fool in a series 5 rx7 fly past the carpark and then seeing red blues after him... :) :burnout:
