Tomorrow its going in for water pump, timing belt and camgear at gavins. Must make sure i bring the right car down! as i don't drive the r33 to the goldcoast usually.
So I gather Gav made it back from the Dutton's rally in one piece? He was pretty excited about it!
Tell the boy's I said hello! I can't ring them all the time from my new job. I can't use the phone. Sucks! I bet they miss my harrassing phone calls but :)
:bs!:
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yeah - i guess so.. not sure whether gavin or one of the other guys is doing it. I assume he has other guys to do stuff too ?
nex's one is in there now.. he's got a big bill though.
I better not get a big bill or i'll cry.
Gav won't be doing it.
Scott of Brett will. Both top guys.
Well Gav did the road tuning (he does all the tuning) and then fine tuned it on Matty Spry's dyno. Gav did most of the tuning but Matty did the economy tuning when I'm not up it. SO yeah, he did do some of it, but not a lot.
I hear he's a wizz at pfc tuning but. That's why gav goes there. It's easier for him to tune with someone who knows what they are dong as well
