  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I didn't mean for people to take that personally, but unfortunately it's true.
I've donated twise to this site because it's worth it. With the amount of knowledge and information on here, it's cheaper than breaking things in your car if there is something seriously wrong.
You don't have to donate much, every cent helps!
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
