  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
gavin wood is pretty expensive.. as i'm finding out the hard way :D
its already up to about twice what i was hoping for :( :(
i mean he's picking up stuff that probably needs to be done (i hope) which is good.. but still - i can't damn afford to get it all fixed anyhow.
