  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
http://www.mrcontrols.com/images/badblock1.jpg
http://www.mrcontrols.com/images/badblock2.jpg
http://www.mrcontrols.com/images/badblock3.jpg
A while back we saw a block failure at the ~700rwhp level on Chemvolt's engine. Here is another failure from toymanf's engine. This engine was doing it's first competitive 1/4 mile run.
Toymanf is not sure how much power he was making on the run, but the dyno he was on while getting the engine set up gave 540rwhp on turbo only (all subsequent runs were done with the tires spinning on the dyno) and the 1/4 mile run on which the engine failed was running that plus a 200 shot of nitrous.
The tune was conservative and you can see that there are no signs of detonation on the piston or cylinder walls. EGT temps were fine. AFRs were in the 11s. Fuel was C16.
The block was a seasoned stock block, bored 40 over. A 1.6mm HKS headgasket held down with ARP studs torqued to 65ft/lbs. It appears that the corner of the block around the #1 cylinder was unable to hold the lifting force that the head was putting on it.
There was at least another 100rwhp left untapped in this engine, but it is unclear at this point if the 3s block is capable of holding that much power over the 1/4 mile.
Any thoughts on how to contain +700rwhp power levels and keep the block intact? Sleeves would not have helped here. I've heard of using 1/2" studs but that is going to require a lot of work and I'm not sure if there is enough material in the block to make that work. Would the 5s block more reliably accept this much power and more?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
