you can have your 1337 but i am 77331 so there.
yesterday i was probably actually doing some work :roll:
Wednesday and Thursdays are the "i'm officially getting paid by the hour so better work a bit harder" ...whoring must be kept to the minimum.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yeah, gordo I was hell busy this week and today is the first real chance I've had to whore. Are you moving that block out of your car on saturday or sunday this week. I might come around to give you a hand. You're only about 5-10mins down the road from my place.
charly: you'd have to probably talk to me to do that.. or shall we just communicate in sign language? But yeah, come one, come all. Not sure who gets the free slab though - maybe i should make it a survivor style challenge :P
I think i said 1pm Sunday would be a good time.. If we have enough people, may not even need special stuff.. May just be able to stand in the boot and lift it out
wouldn't an 8 be the land of herniation if you you were doing it without any mechanical help?
people help me out, is there such a word as "yous" or "you's" or might that just be an indication that the person that typed it has no grasp of the english language? It's bad enough when someone says it, let alone when they type it.
example: "you's decide what you're doing now"
yeah.. i think people have serious problems when they bring serious grammatical problems into a typed form.
They must do it deliberately.
well i got my r33 bill.. i am officially poor as all hell (yet again)... as in last few $ to last me a week poor
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
