  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
im currently researching turbos atm. havent gotten deep into it but im lookig in the direction of a hks 2835pro s. bit expensive i think, and i rekon i could get something similar here for alot less. also looking into what else i need. im thinking:
550cc inj.
bigger fuel rail (?)
f p reg. (?)
fuel pump
some exhaust/intake pipework.
ex. manifold
looking for 270rwkw on light boost. then internals and lets go boost! but then its clutch and a few other things as well. gets very expensive eh.
decent suspension above all really. its shocking atm. king springs on stock struts. :eek:
i think i will have to. power is nothing without driving skill. ive never been on a proper strip before so i'll be pretty nervous i think :D but it'll be good fun. what time you rekon from those mods? my biggest problem is 18" rims and a 35 profile tyre. might get the stock ones widened. i think its good for a 13.5-14.0...
