  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
or is this just driving trucks to/from there?
mind you it is pretty hard work... driving in and out of a pit 12hrs a day or night. normal shift at the moment in 2weeks on and one week off. but there are some that do different things
Costs about:
~$1000 for lessons
~$250 for the test (for the truck)
$37.50 from QLD transport for the test.
Hmmm yeap still be dreamin!
then you claim it all back on tax like i have done :)
there other option is that IT firm that i e-mailed you with
yeah.. heard its not easy work.
I heard of people that know people that have done it for a while :) Good money but tough life. Not for me!
cyrice:
Steal a truck - Free
Learn how to drive it on the run to Perth - Free
Getting killed by the trucky or associated bad-ass bikers you stole the truck from - Free
See, you can do it all for free if you were keen enough.
Really if you are single and can be tight with your money, a mate of mine who has been workin in the blair athol mine, central qld, he has been workin there for 3 yrs and has about $150k saved up in the bank, he's going to try to retire in 3 years with ~$500k, buy several houses and live off them.
But yeah no life and have to deal with other miners, who are normally drunks, no offense!
im so pissed off - what is it with guys :)
Cant they just leave the missus in peace when she's happy?!! why do they have to ruin it then complain you have issues! I mean i didnt have issues before you upset me honey! :)
