  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
or is this just driving trucks to/from there?
mind you it is pretty hard work... driving in and out of a pit 12hrs a day or night. normal shift at the moment in 2weeks on and one week off. but there are some that do different things
Costs about:
~$1000 for lessons
~$250 for the test (for the truck)
$37.50 from QLD transport for the test.
Hmmm yeap still be dreamin!
then you claim it all back on tax like i have done :)
there other option is that IT firm that i e-mailed you with
yeah.. heard its not easy work.
I heard of people that know people that have done it for a while :) Good money but tough life. Not for me!
cyrice:
Steal a truck - Free
Learn how to drive it on the run to Perth - Free
Getting killed by the trucky or associated bad-ass bikers you stole the truck from - Free
See, you can do it all for free if you were keen enough.
Really if you are single and can be tight with your money, a mate of mine who has been workin in the blair athol mine, central qld, he has been workin there for 3 yrs and has about $150k saved up in the bank, he's going to try to retire in 3 years with ~$500k, buy several houses and live off them.
But yeah no life and have to deal with other miners, who are normally drunks, no offense!
im so pissed off - what is it with guys :)
Cant they just leave the missus in peace when she's happy?!! why do they have to ruin it then complain you have issues! I mean i didnt have issues before you upset me honey! :)
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
