  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
i want ur r34 laurn HEHEH!!!!!!!!! its to much car for you to handle i dont wanna see you getting hurt so we trade ok, a girly 4banger for a 6. mines got 2 seats :P that adds sex appeal to some :rolleyes:
LOL Luke .... no deal .... but if your ever in WA i'll let ya have a drive :rolleyes:
Thanks James - certainly is!!
well now it looks like i gotta take a trip over there to see some people hehe, catch up with my mate james, and nadines older sister and her bf that gave me shit about wanting a mr2 he owned a damn civic :|
only nissain motor i have driven was a vl turbo and moved it from my drive way to the front lawn so i could move my car :P
James: Most likely yes ..... I know the car well - just gotta test drive it tomorrow night - if thats all good then its all mine ...... in about a month when the owner comes back from Indonesia and ive sold mine.
:P
anyway forums to slow to switch between states - so i'll catch you all later :rolleyes:
yeh the 3sgte is nice :rolleyes: but why didnt they make a car like the silvia with it in it :P they'd probley be more popular for drifting and shit than an sr20 silvia cause the 3sgte is heaps stronger from what i hear. ohwell toyota is lame, wonder what i would be doing if i brought that supra instead. hrmmm
probley 6foot under hehe
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
