  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Probe into 'drug-fueled sex cruises'
From correspondents in Nicosia, Cyprus
June 25, 2004
CYPRUS police said today they were investigating claims that British and Scandinavian tourists are involved in organised sex romps in the Mediterranean during night cruises off the coast of Ayia Napa.
According to independent TV channel Mega, tourists aged between 18 and 30 are involved in sex and drug orgies during short cruises off the popular southern clubbing resort.
The station also accused the party goers of taking ecstasy pills and partaking in "debauched acts".
Cruise organisers arrange the boat parties inside international waters to escape the long arm of Cypriot law, Mega reported.
The TV station screened censored pictures of naked revellers, as couples engaged in what appeared to be oral sex acts, egged on by large crowds
June 25, 2004
HELL YEAH Where can I sign UP!?!?!?!? :(
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
