  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
wow gordon!
Thats some university lecture material, i think thats the smartest thing thats ever been posted in wasteland
yeah, there was some intelligence for a bit, but thats gone now /phew.. i wasn't the only one !! it was nexus and charly's fault, they started talking gutter intellectual talk and i just felt obliged to jump in - honest!
cause the one i got now is a BPV bypass valve, it actually lets air bypass the turbo into the inlet and also acts as a bov with recurclitation :D pretty cool huh, probley put it on the side where ur hks one is near the throttle body so it can suck air in easier :( so off boost no need for the air to traval through turbo, than intercooler. it just travels from after afm through a litte 1inch pipe to ur throttle body. than when on boost it shuts and works as a bov and if boost is higher hks one helps :)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
